Order of importance
Old Jul 30, 2021 | 08:13 PM
discoinfernoOSV's Avatar
Default Order of importance
So now that I have my cooling system issues resolved (I hope) I'm starting to plan out where I go from here. Next weekend I'm changing the oil, transmission fluid, transfer box, and differential fluids out. I know that's a must, unsure other than oil when those were last done. I have some other things planned that I'm wondering what the consensus order of importance would be. In no particular order here they are:
  1. Sort out SAI codes (p1412 & p1415).
  2. Sort our three amigos codes. They come on and off randomly. Were on today, filled up the tank with gas, haven't come back on. The previous owner said this would happen every tank. Code indicates shuttle valve.
  3. Sort out oil leaks. Thinking valve cover and potentially oil pan gasket or oil seal. Haven't looked too hard at this yet as it is a minor leak.
  4. Replace front driveshaft. The U-Joints were replaced at ~130k miles but not the entire shaft.
  5. Sort out sunroof leaks. Keeping a tarp on it, for now, know it isn't a big deal, but it's tacky as hell.
  6. Deal with some bubble rust around sunroofs and in door frames.
  7. Put rust prevention paints/sprays/whatever on the chassis to prevent rust, remove current surface rust with a wire brush. (This is primarily a beach vehicle for me so this feels like a must-do in the next 6 months.
  8. Something I hadn't thought of that you good people recommend.
Old Jul 30, 2021 | 08:46 PM
redwhitekat's Avatar
Ultraguage
in-line thermostat
pcv mod
Hyundai fuel purge valve
Old Jul 30, 2021 | 08:53 PM
Extinct's Avatar
Diff and transfer case factory fluids are full synthetics, no need to ever replace. but I know some people like to do it.
#3 will be gone once you do PCV mod.
#4 - u joints are all that wear out. If they have been replaced that shaft is good. You can get a spare if you like.
#5. Pull the headliner, drive it for three weeks like that. Look at my post on sunroofs.
#7 Look at rust reformer and fluid film.
These links will will open old threads, scroll down to my list post.
https://landroverforums.com/forum/di...44/#post723598
https://landroverforums.com/forum/di...e3/#post674154
Old Jul 31, 2021 | 12:46 AM
Justice Bikes's Avatar
7th Gear
So Extinct, I've heard about the PCV Mod but I've not been able to locate anything on it. Where might I find some info?
By the way, I installed your Inline Thermostat, nice kit. Thanks for making it available to us.
Old Jul 31, 2021 | 06:01 AM
Extinct's Avatar
PCV mod is the third sticky, top of the forum.
Old Jul 31, 2021 | 10:53 AM
wjsj69's Avatar
Don't forget the centering ball in the dc joint! Mine was getting crispy when I rebuilt my front shaft. Hopefully it was replaced and lubed when the uj's were done.
Old Jul 31, 2021 | 12:23 PM
7th Gear
Thanks Extinct, found it.
Old Jul 31, 2021 | 12:26 PM
Originally Posted by redwhitekat
Ultraguage
in-line thermostat
pcv mod
Have an ultra gauge, love it. Did the inline thermostat mod when I did the cooling system, also love it. Have looked at PCV mod and have read about the fuel purge valve, but need to read more.
Thanks for the links. I'll be checking them ASAP. I didn't realize the differentials and transfer case didn't need to be changed. Reading through a lot of "I just got a new Disco" etc posts I saw commented often to change those fluids. I may still do it, I don't think they were ever locked or even put into low gear before I test drove it.
Hard to say what exactly was done, but I'll look into it.
Wheelspin
Apr 21, 2022 06:37 PM
CollieRover
Nov 17, 2014 09:35 AM
QuakerJ
Feb 12, 2014 10:37 PM
Hyakku
Apr 20, 2012 02:16 PM
RamblingMan
Sep 19, 2007 09:34 AM
