Original water pump in your Disco2? Maybe you should change it...
Old Aug 5, 2021 | 12:08 PM
RA021226's Avatar
Guest
Default Original water pump in your Disco2? Maybe you should change it...
In addition to what you see in the pic, it took out the radiator (pieces of the fan blades) and maybe the alternator (the sudden coolant bath)...~155K miles, btw. M
Old Aug 5, 2021 | 02:08 PM
Extinct's Avatar
So it wasn't leaking before this happened?
Old Aug 5, 2021 | 02:34 PM
Brandon318's Avatar
Oh my.
Old Aug 5, 2021 | 05:10 PM
RA021226's Avatar
Guest
Not enough to be seen....I was losing about a cup a month but could never find the leak.m
Old Aug 6, 2021 | 07:01 AM
mln01's Avatar
What actually failed? Based on the damage to the impeller in your pic it looks like a catastrophic failure of the pump bearing that caused the pump shaft to wobble, starting the chain reaction.
Where were you when this happened? Must've been an "Oh ****" moment. Were you in a place where you could get off the road quickly and safely?
Old Aug 6, 2021 | 07:27 AM
RA021226's Avatar
Guest
That's exactly it. I'm hoping there aren't too many curly metal s;livers in the block....
Old Aug 9, 2021 | 06:06 PM
RA021226's Avatar
Guest
So, the alternator turned out to be fine (for now, anyway) and I bought a boroscope and saw nothing in the block, so here's hoping I'm done with it...nothing like spending $1K on a car worth $2500, lol....
BS50MGSXR
Aug 10, 2021 01:07 AM
CollieRover
Jul 8, 2016 03:33 PM
rmace1
Jan 20, 2012 12:34 PM
mattrickman
Feb 24, 2011 02:16 PM
jwfuller
Sep 25, 2007 04:46 PM
