High flow water pump?
Old Jul 8, 2016 | 12:33 PM
CollieRover's Avatar
Default High flow water pump?
Has anyone tried a high flow water pump? I am really fixated on going to an electric fan set up, rationally or irrationally, and am wondering if this would help the radiator out.
The Tri Flow radiator from Eastwood is tempting, but if the three passes makes the pump less efficient it seems like a poor trade off.
Old Jul 8, 2016 | 12:55 PM
Mskembo's Avatar
The tri-flow isn't dependent on your pump to be more efficient. It's a pretty simple (and ingenious) design. It just creates multiple passes of the coolant through the radiator.
I like electric fans as well. I've seen first hand how well they worked in my 454 Chevelle (700hp engine build). I don't see the water pump as being a limiting factor for the cooling in these engines.
Old Jul 8, 2016 | 01:04 PM
I've read criticism of the tri flow design that it will reduce the efficiency of the water pump.
Old Jul 8, 2016 | 03:19 PM
Mskembo's Avatar
The people leveling that criticism are pointing out that it COULD take more pressure to make it through the system. However, the only change is the routing, so the pressure change would be minimal at worst. The temperature change between the two that is shown would make up for any difference in reduced flow rate (not that I believe there would be any).
Old Jul 8, 2016 | 03:33 PM
Best4x4's Avatar
Unless the Efan can match or exceed the airflow of the original fan blade/fan clutch they're not the answer. Tried a $$$ efan setup on my 08 5.3L equipped H3 Alpha and yeah during the fall & winter it was fine. In the middle of summer it was a HUGE failure and almost cost me a perfecty good engine. Company that made the $$$ setup wouldn't stand behind their product so I went with the OEM setup, new fan clutch, and added a 12inch puller efan and that is a well working setup.
wick_60010
Nov 22, 2017 04:25 AM
A5scott
May 18, 2015 06:34 AM
omarica7
Mar 11, 2014 08:12 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
LRD2&ME
Jun 6, 2011 12:30 PM
