Our 2001 Project DII
Old Mar 26, 2016 | 09:28 PM
  #121
DiscoBuckeye's Avatar
Yay!!!! I broke the top off to get a 22MM impact socket on then heated it (I'm sure I just don't have a torch that gets hot enough) I saw it start to move a tad sprayed with PB (it was the closest) and she spun off!
Now I'm going to let it cool down a bit and put the new one on.
Old Mar 26, 2016 | 10:44 PM
  #122
Charlie_V's Avatar
Nice!!! Congratulations. Be sure to use anti seize on the new one. What a pain! Bury it!
Old Mar 26, 2016 | 10:47 PM
  #123
Its a trophy!
I did clean up the threads as best I could. The new one came with a nice blob of anti seize on it. She runs even smoother now.
Old Mar 26, 2016 | 11:09 PM
  #124
Charlie_V's Avatar
Its a trophy!
Maybe this will usher an end to your engine woes. I am a glass half full person.
Old Mar 27, 2016 | 09:05 PM
  #125
Buckeye I woke up at three this morning with a terrible thought. No worries, I got back to sleep. But that was about a video you sent me on your brake cleaner test. If you look at my video you will see some blue filter material covering the air conditioning intake at the bottom of the windshield. At 3 am I woke up thinking yours had no filter at all, which is common because the stock filter stuff turns to dust.
If that the case you can buy a universal hvac filter at lowes or home depot for peanuts, cut 1 inch strips, and it fits perfectly. That's the blue stuff on mine. There are little keepers placed every few inches that pull off, install filter, press keepers back in place. If you don't do that you get crap in your blower and your drains clog up, getting water all over the carpet.
Time for a nap.
Sleep tight my friend
I should space the hold down thingy's more betta
Old Mar 27, 2016 | 09:40 PM
  #126
Charlie_V's Avatar
That looks awesome. Like a blue ribbon over your engine bay.
Old Mar 28, 2016 | 07:45 AM
  #127
The_OGCJR's Avatar
I'm going to do that!
Old Mar 28, 2016 | 10:47 AM
  #128
Charlie_V's Avatar
It really works. I have a lot of trees over my drive and had to clean my blower and drain nipples every couple of months. Since putting that cheapo filter stuff in no problems for a year.
Chubbs gets the credit. Great mod.
And it is washable!
Old Mar 28, 2016 | 07:03 PM
  #129
This is whats left. I only replaced the Upstream O2 on the Passenger side...so far
Old Mar 28, 2016 | 07:14 PM
  #130
Charlie_V's Avatar
I maintain that the downstream sensors just measure cat function. I ignore them.
That 6 misfire. You've changed plugs and wires, right? No vacuum leaks. Not losing coolant. You checked spark.
ARE you sure that speak plug is tight?
The only other things I can think of are the injector and compression. Very unlikely that a coil is the issue with just one cylinder acting up.
