Our 2001 Project DII
Old Oct 3, 2018 | 04:25 PM
  #211
Charlie_V's Avatar
VERY impressive, pulling it with the engine in the truck (or, most of it anyway)!
Old Oct 3, 2018 | 05:09 PM
  #212
DiscoBuckeye's Avatar
As a few have said, you can do it with the motor in by getting the condenser to be in position (up and tilted forward)
Old Oct 13, 2018 | 09:49 PM
  #213
Lots of progress this weekend so far. New Radiator is in and the heads are on and torqued. Question, I have seen ARP instructions on line say 100 lb ft final torque and 70 lb ft final torque. I went with 70. Only problem is one of the bolts in the kit was a 14mm 12 point and is snapped at 70 lb ft. When the new bolt comes do I just torque it straight to the 70 or sequence it?
Old Oct 14, 2018 | 08:14 PM
  #214
The_OGCJR's Avatar
I followed the method in Rave and used a paint marker on the bolt heads to determine how far they were turned the second time.
Old Oct 15, 2018 | 07:13 AM
  #215
was that with studs or torque to yield bolts?
Old Oct 15, 2018 | 02:23 PM
  #216
Ok, I may or may not have snapped the dipstick tube right above the notch or ring in the tube. I just checked Ebay. I see one but I only need the tube. Any other options other than Ebay?
Old Oct 15, 2018 | 05:22 PM
  #217
jamestfl's Avatar
You 'may or may not' want to give Paul Grant or Abran a shout.
Old Oct 17, 2018 | 09:48 AM
  #218
LOL Will do.
Old Oct 22, 2018 | 06:38 AM
  #219
Lots buttoned up this weekend. Major delay was getting out the broken dipstick tube. Exhaust manifold bolts did not have the spacers so I did not add them.
Old Oct 22, 2018 | 08:18 AM
  #220
The Deputy's Avatar
Did the new/mint-condition/collectors-edition/cutting-edge-technology/glimmering-in-the-sunlight/used oil tube show up Saturday?
Brian.
