Our 2001 Project DII
Old Oct 26, 2018 | 08:56 AM
  #231
DiscoBuckeye's Avatar
Good news! Just be sure to get her bled thoroughly, by running it a few times, letting it cool and refilling coolant, and using the bleeder screw in between a couple times. Before hitting the open highway.
Brian.
topped her off this morning.Great advice.
I have that little voice saying you didn't break in the cam right but I did have her run between 1500-3000 rpms (mostly 2000-3000) for a half hour so I guess I should ignore the voice
Old Oct 26, 2018 | 08:59 AM
  #232
mollusc's Avatar
Originally Posted by DiscoBuckeye
Don't adaptives relearn themselves?
They do eventually (that's what "adaptive" means) but you might have some lumpy running and low mpg in the meantime.
I'm in the final stages of my own reassembly, and I noticed that there is a slight difference between the two idler wheels for the serpentine belt but I forgot to mark them when I disassembled. I don't know if this difference is critical in any way. Do you have any guidance you can share?
Old Oct 26, 2018 | 12:06 PM
  #233
JUKE179r's Avatar
They do but over time. A long time...
Old Oct 26, 2018 | 02:20 PM
  #234
smaller one goes under the tensioner assembly and larger one goes under the AC compressor
Old Oct 26, 2018 | 05:07 PM
  #235
Originally Posted by Charlie_V
VERY impressive, pulling it with the engine in the truck (or, most of it anyway)!
So Charlie I had to post this video. I was bored out of my gourd breaking in the cam and lifters. It made me think of the video spraying brake clean to find a vacume leak
https://youtu.be/lDKgAkX4l0w
Old Oct 26, 2018 | 05:11 PM
  #236
mollusc's Avatar
Mine are both the same size.
Old Oct 26, 2018 | 05:31 PM
  #237
I thought you said that there were 2 different size ones and you needed to know which one went where because you didn't keep track
Old Oct 26, 2018 | 07:53 PM
  #238
mollusc's Avatar
No, I said there was a slight difference. I didn't say size. One of them has a grommet/washer behind it, and the rotating mechanism is slightly different between the two of him. They appear to be exactly the same diameter though.
Old Oct 26, 2018 | 09:57 PM
  #239
ahh ok well I had two different size pullies
Old Oct 29, 2018 | 05:56 AM
  #240
So I'm assuming when I moved the condenser around to remove the old cam and install the new one, I created a leak. The AC clutch is not engaging. I did the check for error codes on the HVAC display and none are listed. Shouldn't I have a low refrigerant error?
