Over Heating
Old Jun 22, 2008 | 05:35 AM
Cult Wine Guy's Avatar
Default Over Heating
Hey Everyone! I have a 96 Discovery with 100k miles and it had overheated yesterday. A ton of fluid a gushed out from the under the hood. There was so much steam that I didnt want open it up so I had let it sit for a few hours to let it cool down. When I had finally got around to check it where the problem wasI had noticed my expansion tank had a good size crack in it when the fluid must have came from.I have checked allthe hoses and they are in good condition. I sure that allI whould have to do is replace the tank but i'm wondering if that could be just a small part to a bigger problem! I've talked to some friends that have other thoughts like the water pump, radiator, heater core, and heater moter. Any thought or ideas and how I could check any of them myself before I get raped by the dealership! Thanks CWG
Old Jun 22, 2008 | 08:00 AM
Default RE: Over Heating
Do you have the old black tank, if so it was replaced years ago because they kept splitting. The new tank is a white clor.
Start by replacing that , filling and bleeding your coolant system and see what happens.
Old Jun 22, 2008 | 08:42 AM
You do not need to go to the dealer.
Like Mike said, just replace your expansion tank, refill and then bleed the cooling system.
http://www.roverlandparts.com/index....mp;ProdID=1715
It would be a really good idea to flush the cooling system before you refill it.
Old Jun 22, 2008 | 03:53 PM
Hey Spike and Mike!
Thanks for the info! Yep, it is the black tank so I guess be doing that once the dealership opens tomorrow!
Thanks again, CWG
SolbergFanBoi
Mar 5, 2012 07:05 PM
unco
May 13, 2011 07:27 PM
99Landrover
Mar 15, 2006 11:08 PM
budley62
Jan 24, 2006 01:28 AM
budley62
Jan 3, 2006 05:36 AM
