Over Heating!!!!!
Old Oct 22, 2014 | 12:00 PM
bmeier's Avatar
yea i took the res tank out and raised it stone cold, no good shops locally, heads never done. That temp gauge is a POS, thats why i dont want to take her out on the road, I feel like the new t sat might have done the trick though im just being cautious, letting her cool down now. I inspected the best i could all around the heads and the rest of the block I dont see any damage or leaking, Would that throw off codes or have any noticeable signs, because theres no smoke from exhaust and motor sounds normal, oil is good , pulled a few spark plugs and all looks good in the cylinders. i appreciate the info
Old Oct 22, 2014 | 12:06 PM
cappedup's Avatar
Getting an Ultragauge is pretty recommended.
Means you arnt relying on the PoS temp gauge in the dash.
UltraGauge OBDII Scan tool & Information Center
Old Oct 23, 2014 | 10:36 AM
bmeier's Avatar
Default overheating
So with the new Tsat everything seems fine, haven't been able to take her for a long test drive as i discovered the the coolant tank is leaking from bottom outlet. Ordered new tank and cap. Will have that replaced tomorrow.
The ultra gauge looks awesome, definitely getting one!!
I was on their website but couldn't find any info on whether it pulls Abs fault codes, just curious.
Old Oct 23, 2014 | 11:15 AM
MonteroMan's Avatar
Default Only one fix that works
Originally Posted by bmeier
I was thinking it was gonna be either the thermostat or waterpump, Im going to order those tonight, Are there specific ways to test these to see if they're bad? Also its been awhile since ive done a rad flush on a truck, whats the correct procedure?
Only this works
Old Oct 23, 2014 | 11:19 AM
drowssap's Avatar
thanks for coming back and saying was the tank, hopefully more people will start pressure testing their systems.
SolbergFanBoi
Mar 5, 2012 07:05 PM
unco
May 13, 2011 07:27 PM
99Landrover
Mar 15, 2006 11:08 PM
budley62
Jan 24, 2006 01:28 AM
budley62
Jan 3, 2006 05:36 AM
