over heating issues
Ok i have replaced the radiator, waterpump,thermostat and electric fan. I finally got a chance to drive it tonight after talking with a guy who may want to trade for an older bass boat. I drove it about 18 miles and it stayed steady and didnt overheat at all. Heat stayed constant and everything seems fine. I pop the hood and notice a slight hiss from the overflow tank. I called my friend who is a foreign auto shop owner and he says that its normal to hear a little from the overflow from time to time on a rover. I have bled the system 2 times via the t tube on the top radiator hose and it has pumped a little air out each time. Thats what scares me. I dont want to give this guy a giant piece of crap so i wanna make sure its not going to overheat. Is the distance i drove long enought for something to happen? thanks for any info. I have since bought a lr3 so dont have much need for the disco 2, wife says i cant keep it...lol
I'd try it fully warmed up, but if you are not hearing the bubbles pass thru the heater core under the dash, you may be in the clear. Here's pix of something to look for with the scanner. And you may want to look at https://landroverforums.com/forum/lr...light=download for the new ride.
Well I messed with it last night. When I got there the coolant tank was almost empty. Oil level good and no leaks on floor. What would cause it to be empty. It didn't overheat the night before to shove it out the tank. I filled it up and fired it up again. Got to normal temps and had good heat. Bled the system again. I'm going to check it tonight in hopes that the tank is full. Bleeding a coolant system shouldn't be this hard. I think I'm just gonna sell it for cheap. Let whoever know what's going on. I don't want to trade this guy even though he really wants it. If te coolant tank is full tonight I'm gonna drive it again and see how it does or if the hiss is there after shutting it off.
