Overheat at Idle or Under Load - I'm stumped.
Old May 23, 2015 | 12:47 PM
disc oh no's Avatar
Originally Posted by Externet
I would not call it overheating under 212F+, even with a 180F thermostat.
Check you are not misleading yourself comparing summerish ambient temperatures with previous winterish ambient. Would explain "running hotter than it used to" if the 'used to' was winter when parts were replaced.
A 180F thermostat does not mean it will not go above 180F. 180F is the temperature when it will send coolant to the radiator.
I think this is a good point. I think mine runs somewhere around 212F even in fairly cold weather. By fairly cold, I mean for where I live in the northeast, it gets down to -15 or -20 on rare occasion. I think I checked mine when it was around 15-20 above zero and it was somewhere around 210, if I remember right. It worried me too, but I never had any real trouble with it. So eventually I just forgot about it.
If you are going to replace the thermostat, you should hang on to the old one and hollow it out. That way, if you suspect a thermostat problem, you can always throw that one in and see if it still runs hot. Also, it's nice to have a hollow one around for cooling system flushes.
Old May 25, 2015 | 04:24 PM
Tim P.'s Avatar
That's a good tip on the hollowed-out thermostat, will definitely do that.
So, I ordered the gray high-flow T-stat from Lucky 8, flushed the system again, installed the t-stat and a bottle of Watter Wetter... MOST of the time the temp is a few degrees lower, but it still creeps up to 208-210 at long stop lights and in the 203-205 range when I'm at highway speeds for more than a couple of minutes.
The only thing I can think of is that maybe there is some gunk really lodged into the passages on the radiator that I didn't see with the scope, and isn't getting cleared out by the chemical flush.
When I replaced the water pump, the old gasket was literally falling apart in chunks. There's a chance it could be bits of the old gasket clogging it up.
Going to pull the radiator and swap it out with my other DII, see if that helps.
-Tim
Old May 25, 2015 | 06:08 PM
disc oh no's Avatar
-Tim
I don't know man, I swear mine runs that hot and the inside of my engine (the last time I had it apart) looks new and shiny! What I can see inside the radiator looks good, I can't honestly say I've broken it open though. lol.
Old May 27, 2015 | 04:58 PM
jfall's Avatar
First things first.
Take the Motorrad thermostat out.
Get a hammer. Smash it into a pulp and put it into the recycle.
1) Get a grey Land Rover Discovery soft spring 180 degree tstat in the real Land Rover Box.
2) Replace the Radiator with a brand New Nissens from Rockauto.com
3) Replace the fan/fan clutch.
Then BE HAPPY.
All fixed.
Will not over heat or heat up at idle now.
Old May 28, 2015 | 06:15 AM
drowssap's Avatar
yuh that it, once you replace the complete cooling system; then you will be happy
Old May 29, 2015 | 03:30 PM
jfall's Avatar
Worked for me.
And replacing all three - the trifecta is ALL that worked.
I never had the AUX fan come on IN THE WINTER
in a parking lot again.
Not wise to be pennywise
and pound foolish.
Engine is a terrible thing to overheat and replace..
Radiator $230.
T-stat $70
Fan and clutch $200..
new engine - $4000
Installation $1500?
Or more?
To each their own.
I choose my misery up front.
Replacing this stuff is money in the bank
and insurance.
Old May 29, 2015 | 07:48 PM
disc oh no's Avatar
Originally Posted by jfall
First things first.
Then BE HAPPY.
All fixed.
Do all this and you're good for another 3,000 miles!
Old May 30, 2015 | 09:42 PM
tndave's Avatar
^ lmao
kid A
Jan 13, 2016 06:10 PM
jcostello
Feb 20, 2007 07:18 PM
jcostello
Oct 27, 2006 03:39 PM
Taipan
Freelander
Oct 15, 2006 02:52 PM
