Overheated....HELP!
Old Nov 25, 2011 | 04:18 PM
kpl1228's Avatar
After talking to you, Mike, so far so good! Thanks for all of your help.
Old Nov 25, 2011 | 07:38 PM
With respect to overheat light on when truck cranked cold: See this from info previously sent -
If the engine coolant temperature gauge receives no input or the input is out of range the temperature gauge will read cold and the high coolant temperature warning lamp will be illuminated.
So if you knocked the wire loose off the engine coolant sensor it would do this when truck is cold. See attached pix from RAVE
File Type: pdf
allen
Sep 11, 2012 09:34 PM
Bert
Feb 20, 2009 06:37 PM
dlkk
Aug 3, 2007 09:12 AM
unco
Dec 2, 2006 06:32 AM
BMWLR
May 12, 2006 01:44 AM
