overheating disco 2
Old Sep 10, 2011 | 10:50 AM
ismaeld2's Avatar
6th Gear
Question overheating disco 2
hello, i got a 2001 disco, i just replaced the radiator 2 weeks ago because i broke the other one mudding, it start overheating so i i check the fan clutch and it was bad so i decided to replace it with an electric one, it works fine, it does not overheat while driving in the city, but ones i drive it in the highway and stop it does overheat, also im getting a code that says catalytic damaging, any ideas??? please help is driving me crazy!!
Old Sep 10, 2011 | 10:19 PM
Electric fan is not supplying enough cooling to handle cool down of engine just run at highway speed. When driving on highway, then stopping, engine still has thermal lag time to cool off. If electric fan thermostat can be adjusted, that may help. May be spacing of fan from radiator, cowling, fan blade location with respect to cowl. And I bet those codes are telling you the truth. What temperature does your scanner tell you the coolant is when driving, idling, driving in town, etc? If you are defining overheat by a top of the gauge reading, you can be doing serious damage to the engine, need to stop driving until fixed.
Old Sep 11, 2011 | 05:08 PM
ismaeld2's Avatar
6th Gear
well i found a coolant leak on the throttle body, so i guess that's how it was losing the coolant and overheating, plus it was socking air on the side of the intake that was why it was misfiring, so tomorrow anyway im replacing the cats too, and i adjust the thermostat for the fan, the fan cover the hold radiator and it moves a lot of air, i think more than the original fan.
Tom Condon
Oct 19, 2006 08:22 PM
riebs
Aug 29, 2006 03:05 PM
procurbusa
Aug 14, 2006 03:19 PM
forbin10
Dec 1, 2005 07:55 PM
bakerww
May 24, 2005 09:35 PM
