Overheating question
Old Oct 17, 2021 | 10:23 PM
Colorado David's Avatar
Default Overheating question
Last week I had an issue with my temperature going up. I pulled over and opened the hood. The radiator reservoir tank was spewing so I called for a tow. After getting it home I thought it was the water pump. I replaced the water pump today. It didn't fix the problem. After a normal warm up period, the reservoir is pressurized. My head gaskets are less than 15,000 miles old and there's no antifreeze in the oil. I ordered a warm climate thermostat today. Can anyone think of some other reason?
Old Oct 18, 2021 | 06:35 AM
mollusc's Avatar
There are dozens and dozens of threads on this forum about people investigating overheating issues. It's highly likely that what's causing your problem has been covered in great detail many times..
Just because you don't have oil in the coolant and your head gaskets are recently, that doesn't mean you don't have a cracked block or failed gasket again.
Old Oct 18, 2021 | 09:03 AM
whowa004's Avatar
or a bad radiator. If you need a rover shop in CO check out Roadside Werx and tell them Will sent you.
Old Oct 24, 2021 | 03:46 PM
I'm sure there are dozens of threads, but nothing came up when I searched. So far I've replaced the water pump and today, the thermostat. I didn't let it heat beyond normal temperature, but I could see bubbles going into the expansion tank from the throttle body heater return line. what does that mean? I'm fairly sure that is how the expansion tank is getting pressurized.
Old Oct 24, 2021 | 04:23 PM
Extinct's Avatar
Blown hg, sorry
Old Oct 24, 2021 | 04:28 PM
Dave03S's Avatar
The search function works better if you use the search engine of your choice and type in Landroverforums.com then the subject you are looking for.
The search function on this actual web site sucks for quickly finding anything.
jnwinca
Jul 20, 2012 03:30 PM
Disco2Fever
Feb 25, 2010 11:31 PM
wellerdoug
May 12, 2005 05:22 PM
