Oxygen Sensor Codes .... Relatively new sensors
Old Sep 29, 2012 | 07:56 PM
starcraft1's Avatar
Default Oxygen Sensor Codes .... Relatively new sensors
So I was driving the other day and I got a CEL. When I got home I read the codes and I have the following: P0141, P0161, and P0140. These are all oxygen sensor codes for the second bank sensors. The funny thing is I replaced all 4 sensors about 5,000 miles ago. Is there a possibility that they kicked the bucket this early or do I have a different problem to deal with. Any help will be appreciated.
PS I have 168,000 miles on the truck
Old Sep 29, 2012 | 08:04 PM
Check and see if oil from your valve cover has leaked into the 02 connections, if so fix your clean and clean your connections.
Old Sep 29, 2012 | 08:24 PM
starcraft1's Avatar
Thanks Mike, I will check on them in the morning. Arent the rear sensors further back though. I know my valve covers are leaking a bit, but that would seem to effect the front ones, not the rear. Could oil covered front sensors cause mishaps in the rear.
Old Sep 29, 2012 | 08:36 PM
My mistake, but check them anyway.
You should have a 1 year warranty on the 02's from the supplier, if needed.
Old Sep 30, 2012 | 01:44 PM
lr2001silver's Avatar
Banned
But yes you can purchase a brand new oxygen sensor that is bad or yes a oxygen sensor can fail that fast. Now have you had any problems prior to changing them or was it just as preventive maintenance?
Old Sep 30, 2012 | 08:14 PM
starcraft1's Avatar
They were getting old and I was throwing codes so I replaced them all. First the front two, then the rears a few months later. I took Mikes advice today and cleaned the connections. After a few hours of driving, accompanied by a number of on/off cycles (going into stores and such). I havnt gotten any codes. Perhaps they were dirty/loose. I wanted to ask if it's a good idea to put dielectric grease on the connectors. I havnt in the past but I do use it on the plug wire connections so I figured it might help here. Thanks for the help
Old Sep 30, 2012 | 08:16 PM
starcraft1's Avatar
Oh and one more thing I failed to mention.... The sensors I got are OEM equivalent bosch ones not cheap imitations where you have to splice in the connectors.
Old Sep 30, 2012 | 09:33 PM
Banned
Okay great news!!! Yes dielectric grease is good, and dirty or loose connections will interrupt any connection and cause problems.
ITMagician
Sep 20, 2015 08:47 PM
Charlie_V
Sep 5, 2013 09:03 PM
jsyonker
Sep 4, 2011 06:01 PM
adowgiert
Feb 2, 2007 09:11 PM
riebs
Aug 21, 2006 11:48 AM
