Oxygen sensor help
Old Jul 5, 2015 | 01:19 PM
JoeLena's Avatar
Default Oxygen sensor help
2004 D2. Upstream passenger side sensor replacement.
Cannot get the plug (connector) part off the chassis. Cannot see it well to find out how the plug is retained to the engine and the side of the plug with the tab is facing away from me so I cannot get a screwdriver in to release the connection.
What kind of retainer holds it in? I cannot really tell from feeling it and don't want to just pry away. Just need to know how to get the plug off the engine to swap ot out. Driver side was sinple, but passenger side is killing me!
Old Jul 5, 2015 | 01:34 PM
NickAdams's Avatar
I'm certain mine pulled straight up, but that might have been due to a damaged connector, and not locking or engaging. Good Luck.
Old Jul 5, 2015 | 02:00 PM
JoeLena's Avatar
Well my lovely and talented wife was able to get her hand far enough to depress the clip and pull enough on the wires to get it disconnected so all is good. Still do not know what kind of retainer is used and hopefully will not have to do again to find out.
Old Jul 5, 2015 | 08:34 PM
Fallstaff's Avatar
Just for future reference: It's a two part ordeal. First it's pull the whole plug assembly off the metal tab on the vehicle, then the second is pull the two plastic parts apart with a separate tab.
Helps to have a trained spider monkey on hand too.
What is really needed is one that is easy to get at to practice before trying to do it with your arm buried deep in the innards and the drive shaft pressed up against your face.
Old Jul 6, 2015 | 07:04 AM
JoeLena's Avatar
Could never get it off the metal. Still have no idea how it is attached. Makes you want to find a LR design guy and kick them in the nads.
Old Jul 6, 2015 | 10:31 AM
mln01's Avatar
That sentiment has been expressed frequently and vigorously through the years on this and other Rover forums. Maybe that's why the Rover engineers and designers lie low and are never heard from on these forums. 😊
Old Jul 6, 2015 | 11:03 AM
drowssap's Avatar
Once removed from the metal strip you can reroute them so the oil from the leaklng valve covers wont run into the connector
Old Jul 7, 2015 | 11:06 PM
jfall's Avatar
really hard to get off.
You first need to get it off the metal tab without breaking it.
Then you need to use two hands up there to press and pull.
I think I was able to get it off once by leaving it on the metal tab
and then pressing in on a tab.
Best to look and study the O2 connector and know exactly what you should press before you guess.
There is a good chance you will break the plastic part that locks it to the metal tab and it will just be in mid air and eventually find the exhaust pipes?
Be careful R2
Old Jul 9, 2015 | 05:36 PM
Make sure when replacing the front 02's, to replace both for equal air fuel ratio to both banks, always clean the connectors with electrical contact cleaner and use die electric on the connections before connecting them thus stopping and oil from getting in and messing up the new 02's.
xb70valkarye
Oct 21, 2009 05:26 PM
raidernine
Sep 3, 2007 08:22 AM
bonedoc
May 1, 2007 06:49 PM
EATMAN
Nov 10, 2006 12:15 AM
xb70valkarye
Feb 8, 2006 01:52 PM
