P.S. Fluid Bubbling?!
Old Jan 24, 2011 | 09:22 PM
ralba1976's Avatar
4th Gear
My power steering reservoir has foamy bubbles and my disco is making a humming/buzzing sound when I turn the wheels. It looks like one of the lines might be leaking. If there is are causing the reservoir to foam, how would I bleed the system? Would I need to replace the hoses or pump also? Any help you could give me would be great. I am thinking about doing something to it this weekend.
Old Jan 25, 2011 | 07:47 AM
sloan74's Avatar
Originally Posted by edvan94
Not bubbling, it's flowing.
/this
Normal.
Old Jan 25, 2011 | 07:50 AM
sloan74's Avatar
If it's foaming, then there is air in the system.
I am not 100% certain, but I think these trucks do not come with bleeder values on the power steering. Try jacking up the axle until the wheels have most of the weight off them (the tires still barely touching the ground though), leave the engine off, and turn the steering lock to lock (left to right). With no power and and slight pressure on the wheels, turning the wheel might push out more air in the system. Worth a shot. You might be able to pin point a small leak this way also, if it exists.
cbrf23
Feb 3, 2015 12:01 PM
COOTER-GUY
Nov 19, 2010 06:27 PM
Rangie_
Aug 7, 2009 08:03 AM
mackshawnd
Feb 28, 2009 05:44 PM
dickensheets
Nov 6, 2006 12:32 AM
