P0150 and P0174
Old Dec 18, 2009 | 06:34 PM
jack112286's Avatar
4th Gear
Default P0150 and P0174
Hi Guys, I got an 01 Discovery SE7 with the P0150 and P0174 Code. I searched online already but it seems my car is not a 02 or maf problem.
Heres the main problem, Bank 2 O2 (passenger side b4 cat) reads lean, but the exhaust smells very rich. But I still replaced the O2(bank 2 sensor 1). On top of that, bank 2 fuel trim is at 99 %, but Bank1 is completely normal. If the Maf is bad, I suspect both bank would go rich. However in this case, only bank 2 seems to be wrong. after I replaced the O2, it did not solve the problem, it still runs rich but the o2 gives a lean signal. BTW, when I took out the old O2, it ar dark as used engine diesel oil.
I read on this forum (http://www.lrrforums.com/showthread.php?t=7324) that theres a stepper switch in this thing that gets plugged up. is this a common thing?
Thanks for your reply, I hope I give you guys enough information.
Rearden Steel
Aug 8, 2014 03:39 PM
chicane
Jul 19, 2014 08:23 AM
richief556
Aug 5, 2010 09:08 AM
hriant88
Apr 30, 2008 07:33 AM
