p0154
Old Apr 25, 2013 | 07:03 PM
umwolverine's Avatar
Default p0154
Hey guys-
The weather is getting warmer in Chicago and I am back to getting some stuff done.
I've had an intermittent P0154 code pending and it is my final remaining code. The check engine light is not on and I am not seeing any apparent symptoms, but since it comes and goes I am assuming this is something I need to take care of.
I changed the plugs and wires (Magnecor 8 MM and Bosch plugs) and the code still shows up as pending every once in a while.
I know the code indicates that there is no activity in my front passenger O2 sensor. Is my best bet to replace the sensor and if so, is it pretty straightforward if I follow the Rave manual?
Is there anything else that could cause this?
Thanks
Dustin
Old Apr 25, 2013 | 07:14 PM
roverguy7's Avatar
First step would be to disconnect, clean, and reconnect the connector for the sensor, they like to get oil inside there.
Old Aug 3, 2013 | 02:23 PM
jwigum's Avatar
Hey, any luck with the P0154? I'm getting a consistent alarm for P0154 on my UltraGauge, but no check engine light.
I've read replacing sensors should be done in pairs. Is it worth cleaning one, or should I replace the pair?
Old Aug 4, 2013 | 03:53 AM
BCDisco2Lando's Avatar
I just cleaned our o2 sensors plugs with contact cleaner as the 2 front ones were full of oil but you have to pull the white part out the plugs to really get them clean.
Old Aug 4, 2013 | 08:55 AM
If you have a 154 that comes and goes and you are at the 100,000 range, I would suggest you replace both front 02's and be done with it.
BCD, you might want to tighten or replace your v/c gaskets to stop the leaks which can also take out your crank sensor.
Old Aug 4, 2013 | 10:17 AM
Already done, this was all from the previous owner.
Old Aug 4, 2013 | 01:39 PM
Doesn't mean that 1 sensor hasn't failed or have oil in the connection.
Old Aug 4, 2013 | 06:32 PM
jwigum's Avatar
Yeah, I'm right at 106K. The P0154 seems to have gone away as mysteriously as it arrived... I'll put oxygen sensors on the list, right after I get this lousy window regulator replaced.
Old Aug 5, 2013 | 08:13 AM
If you are looking for a new window regulator, might try E-Bay, a friend of mine bout a set of 2 front window regulators for just under $100.
2000 DII
Oct 8, 2009 11:36 AM
lipadj46
Jun 10, 2009 08:02 PM
samue23
Jun 11, 2007 07:11 PM
wbstyles
May 17, 2007 02:38 PM
landbeater
May 1, 2007 12:15 PM
