P0154, P0174, & P1174 Codes?
Old May 16, 2007 | 12:18 PM
Rondo's Avatar
Default RE: P0154, P0174, & P1174 Codes?
ORIGINAL: wbstyles
Right. The CES lightis back on now. I am going to have it read again to see if it comes up with the same codes. I guess I should check to see if the o2 sensors are properly connected. I should probably just go ahead and replace all four sensors, huh?
Thanks,
Wm
Don't waste your money unless you have determined they are bad. Check the connections, scope the sensors if you can, and THEN replace them. Or if you want to skip all the diagnosis and replace them you may solve your problem when you plug in your new sensors all the way
Old May 16, 2007 | 12:53 PM
okdiscoguy's Avatar
If you are not ready to replace them, check the passenger side front sensor. The wires have a habit of laying on the cat. No activity means the wires are cut or it is unplugged. Might be that it is just totally fried too. Bank2 sensore one I think is for RH front. I was checking my truck and found the wire laying over on the cat. Check this first...
If you have 127K on it, you will get better performance out of your truck if you replace all 4. If you have the $$ and they haven't been changed, change them all.
Old May 17, 2007 | 02:34 PM
wbstyles's Avatar
Is there any way you can tell if they have been replaced?
Old May 17, 2007 | 02:38 PM
okdiscoguy's Avatar
Thought you might have reciepts.
jallen9
May 8, 2013 12:24 AM
Antmen
Jan 16, 2013 03:53 PM
baburhan
Sep 20, 2010 02:42 PM
787tech
Jul 9, 2008 02:43 AM
hriant88
Apr 30, 2008 07:33 AM
