P0154, P0174, & P1174 Codes?
ORIGINAL: wbstyles
Right. The CES lightis back on now. I am going to have it read again to see if it comes up with the same codes. I guess I should check to see if the o2 sensors are properly connected. I should probably just go ahead and replace all four sensors, huh?
Thanks,
Wm
Thanks,
Wm
If you are not ready to replace them, check the passenger side front sensor. The wires have a habit of laying on the cat. No activity means the wires are cut or it is unplugged. Might be that it is just totally fried too. Bank2 sensore one I think is for RH front. I was checking my truck and found the wire laying over on the cat. Check this first...
If you have 127K on it, you will get better performance out of your truck if you replace all 4. If you have the $$ and they haven't been changed, change them all.
