P0207 P1207 Help
Old Feb 11, 2009 | 06:31 PM
azazel_18_2's Avatar
Default P0207 P1207 Help
I have a 98 Land Rover discovery that has been great. Today I had this problem pop up. I checked the wires to my cylinder 7 injector and it was fine. My check engine light is on and has codes 1207 and 0207. Has anybody else ran across this? I have new plugs (NGK) and wires on it and they are on in the correct order. I know LR is known for electrical problems I just hope we can figure these out because I can not afford to take it in.
Old Feb 11, 2009 | 07:29 PM
Default RE: P0207 P1207 Help
How many miles on your truck, how often do you change your fuel filter and what brand of wires are you using? Answer all the questions.
A 207 is a malfunction injector on # 7, 1207 is a #7 injector open circuit or ground short.
Old Feb 11, 2009 | 07:36 PM
I have had it a few years and have not changed the fuel filter. I have a new one and will change it today or tomorrow. I replaced the wired with NGK wires. They are a pretty good quality. Truck has 81k miles on it.
Old Feb 11, 2009 | 07:52 PM
Let me know what it takes to get the injector working again, if you can.
Old Feb 11, 2009 | 08:46 PM
If I can? Come on man have more faith than that. I may just have to swap injector seven with 5 and see if thst sets off injector 5 messing up. I will let you know!
Old Feb 12, 2009 | 08:45 AM
okdiscoguy's Avatar
I was going to suggest that, but you never know how saavy people are. Start there, and let us know what you find.
Old Feb 21, 2010 | 01:25 PM
just_dw's Avatar
What was the final fix? New injector? I have the same two codes for the same cylinder.
Old Feb 24, 2010 | 06:35 PM
just_dw's Avatar
ok, for anyone wondering, the fix was a replacement injector. Given the codes and symptoms, I ordered a reman. injector, installed it, and now it's running fine - no codes.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
