Rear defroster terminal came off
Old Feb 20, 2010 | 06:23 PM
leadfoot's Avatar
Default Rear defroster terminal came off
The rear defroster terminal, where the cable connects to the windshield came off. What do they use to attach this terminal to the glass? It looks like normal soldering stuff, but I tried with my soldering gun and it won't stick.
Old Feb 20, 2010 | 08:01 PM
Did you clean it with flux first?
Do you have glass coverage on your truck?
Old Feb 21, 2010 | 09:40 AM
BajaXJ92's Avatar
If I remember correctly, the strips on the window are made of copper, hence why soldering them won't work. I'm also not even sure if you can weld/solder copper.....
Old Feb 21, 2010 | 09:46 AM
Mrmerlin's Avatar
check out a local parts store they may have some kind of metallic adhesive that will bond the metal together and still conduct elex, there is also a defroster strip repair kit maybe you could use this to stick things back together.
Have a IR gun handy to see how your repair went, you want to check the temp of the bond area, if its say over 150 degrees then the glass could crack as the resistance will be very hi and the rest of the defroster wont get as warm
Old Feb 24, 2010 | 07:48 PM
Dogspit's Avatar
3rd Gear
Default terminal
sand with some smooth abrasive cloth or s.o.s put solder on the terminal heat a lot then put it on the window (the spot you just sand) hold it with your solder gun couple of sec and you should be good to go (don't heat it too much watch your backglass)
slickwilly1976
Jan 21, 2015 04:57 AM
hawkridesdirt
Oct 22, 2011 10:51 PM
G4AKumar
Feb 26, 2010 04:33 PM
Deb99DiscoII
Nov 1, 2007 07:46 PM
99XJ
Jul 19, 2007 09:22 AM
