P0308 Cylinder 8 Misfire - New Plugs & Wires
Old Jun 8, 2021 | 07:32 PM
mln01's Avatar
Finding and bypassing the TBH leak is a good thing, but there's no way it would have caused a misfire.
It's unlikely a problem with a coil pack. DIIs use something called a wasted spark ignition system. Cylinders are paired on the coil packs. Cylinder 8 is paired with cylinder 5. If it was the coil pack, you'd likely have a misfire on #5 also.
I know it's some extra work, and you'd have to remove and replace the upper intake, but before buying new injectors you could try swapping injectors (#8 and any other one) and see if the misfire stays on 8 or moves to the swapped cylinder.
Old Jun 8, 2021 | 09:33 PM
Extinct's Avatar
I second swapping the injector. I have helped a couple guys with bad sets of new injectors, moving it is the only way to validate it is or is not the injector. I recommend moving it to number 4 or 6 as they are on a different coil pack.
Old Jun 8, 2021 | 10:00 PM
T-rex's Avatar
Yup - check the injectors are fully seated. I had one of the bolts holding them in come loose years after a head gasket job - sometimes it would run fine sometimes it wouldn't - all until you almost couldn't drive it. Did the same things, plugs and wires - then coils. I was about to do the drive of shame and take my truck to a professional mechanic when I thought to check that the injectors were in and down all the way.
GOOD LUCK!
Old Jun 8, 2021 | 11:09 PM
sdtimb's Avatar
Thanks for the advice. I'll take a look a the injectors. Fingers crossed.
Old Jun 11, 2021 | 10:34 PM
sdtimb's Avatar
I ran a lazy vs cheap analysis and decided to replace the coils and injectors instead of troubleshooting further.
I just wrapped up installation of the new coil packs and six* refurbished injectors. Fired it up....and took it around the block a couple times. The Beast is running great!
I'm still a tad bit hesitant. After I replaced the wires it took a ~10 miles for the P0308 to return. After repairing the coolant leak I could immediately tell it wasn't fixed. However, this time around it's running much smoother and has great power.
*I ordered a set, 8, but only received 6. Fun times. Since I was only having trouble on cylinder 8, I went ahead and installed the 6 refurbished injectors. I'll try to get a refund for the two missing injectors....or maybe have a couple around for spares / next time I pull the upper intake.
03SilverDisco
Sep 25, 2020 05:41 PM
mdwman
Aug 2, 2014 05:24 PM
unstable
Aug 21, 2012 10:33 AM
Bryan H
Sep 3, 2011 10:42 AM
xb70valkarye
Oct 23, 2007 12:50 PM
