P0332 knock sensor low voltage
Guys I need help. I recently came across a code p0332. And found that the wires to the knock sensor connector burnt. Upon peeling the wires back I found that the harness two wires go back into a single wire. Rave says its 2 wires but I can't seem to find the other one.Using premium fuel and changed the sensors over so I know it's not the sensor. Any help is appreciated. Btw the truck won't pass emissions w/o the code being gone. Let me know.
Ok guys fixed the problem thanks to savannah buzz. I peeled the shielding back on the coax cable. I then crimped a connector to that shielding and tied both sides of the damaged wires together. I then crimped connectors to the inside wires and connected them via crimped wire. No more codes! I'll post pics later.
Yes...
This is a shielded wire and the shield needs to be intact for a valid signal to pass to the computer.
I ended up getting a replacement wire out of a recycled harness to replace the entire wire once it was pinched and compromised. Tried it for a bit with a solder job but it kept throwing codes.
Very sensitive it is.
Richard Gallant (01-17-2022)
austinlandroverbill
07-19-2019 09:19 AM
