Knock sensor wire harness
Old Oct 22, 2018 | 01:58 AM
TheMgmt's Avatar
Default Knock sensor wire harness
Hello,
I’m trouble shooting a knock sensor bank 1 code p100 (210) -read off of a zues code reader @ shop- I came across a double zip tied sensor and a taped wire. My plan is to simply replace the sensor and the wire harness that runs to both knock sensors.
I Cannot Find The Harness. The wire disappears into the engine somewhere. Anyone replace the whole wire assembly before and or have a part number?
I’ve got the rave, and DS2 98-04 parts & accessories off Rimmer Bros -really nice if you don’t have it I’ll attach a pdf.
Thanks.
File Type: pdf
Old Oct 22, 2018 | 08:05 AM
CollieRover's Avatar
The wire on the LH side runs along with the Fuel Injector wires under the Upper Intake, comes out behind the A/C compressor, then goes down below the A/C/PAS Bracket under the Knock sensor heat shield(under the exhaust manifold).
The wire on the harness is an internal wire with the ground wire wrapped around it, so it looks like a single wire, I am sure there is a name for that, but I do not know it, difficult to work wifh, but I recently did mine so it is possible.
Old Oct 22, 2018 | 09:44 AM
Dave03S's Avatar
The name of the wire type is coaxial cable. Replacement is the best way otherwise a damaged shield will allow electrical interference to the low voltage signal riding on the center conductor.
Old Oct 22, 2018 | 12:41 PM
TheMgmt's Avatar
Ya I’m looking to replace the harness, thanks for laying out where it is.
Anyone have a part number?
austinlandroverbill
Jul 19, 2019 09:19 AM
ServerGuy
Apr 3, 2015 07:51 AM
Disco(vering) more problems
Jul 21, 2014 11:35 PM
