P0335 Crank Position Sensor Error
Old Mar 3, 2014 | 11:57 AM
toad2's Avatar
Default P0335 Crank Position Sensor Error
Is that correct? Last nite I shut off my 04 and talked to a buddy for 10 mins, then jumped back in the truck to leave but it would not start. Just whirled and whirled but never kicked. Let it set a few, and it started right up. Then driving home, took my foot of the gas and it stalled. Pulled over, same thing. Whirled and whirld, nothing. Waited a few and it started.
Pulled the codes today and saw P0335, looked it up and i found Crankshaft Position Sensor Signal Error.
Could that be my problem?
Thanks for any info.
Chris
Old Mar 3, 2014 | 12:11 PM
MarkSF's Avatar
For some reason, when they fail, they often start with some kind of heat-soak related issue. So when you shut it off, the sensor got nice and hot and went open circuit. It'll only get worse, yes - replace it.
Old Mar 3, 2014 | 12:23 PM
toad2's Avatar
Thanks Mark.
Woody Reems
Jul 14, 2009 08:30 AM
oljohnboy
Mar 30, 2009 08:54 PM
wosmo
Aug 7, 2008 11:24 PM
DiscoOn22s
Apr 19, 2008 05:12 PM
lacruiser
Feb 28, 2008 07:24 AM
