P0441 Again
Old Jun 16, 2020 | 11:48 AM
  #31
cvhyatt's Avatar
Originally Posted by Best4x4
The line down by the bell housing has a nipple on it with a green cap from the factory. Maybe that is your issue.
Thanks Best. Do I need to pull off the intake to get to it? Seems pretty crowded back there.
Old Jun 16, 2020 | 12:47 PM
  #32
Best4x4's Avatar
It's pretty tight especially with SAI but I've been able to reach a few without removing the intake.
Old May 5, 2021 | 01:05 AM
  #33
Discorama's Avatar
Did you finally find the cause? I am struggling with the same problem and smog is due.
Old May 5, 2021 | 03:50 AM
  #34
cvhyatt's Avatar
Yes I did. My air intake tube had a hole in it where it connects to the throttle body. It suspect it was pulling unmetered air in. Once I fixed the hole my issue went away and I have had no issues since.
Old May 5, 2021 | 12:27 PM
  #35
Discorama's Avatar
Thanks a lot, I will check my intake system for leaks again.
I still don't understand why an intake leak would throw a P0441, which means "incorrect purge flow". According to the manual the test of the EVAP is performed after engine shutdown. I pulled the codes after coming home and nothing, one hour later I pulled the codes again and a pending P0441 showed up. The test is done
by pumping air into the EVAP system and measure the pump currents. If the system is sealing correctly, the current is above a certain threshold (workshop manual 17-2-42, I have a positive pressure leak detection type). Both purge valves are tight, I checked the old and the new one. The only explanation is that the test might open the purge valve, but that isn't mentioned in the manual.
Antmen
Jan 11, 2020 06:52 PM
s10lowrider1994
May 16, 2013 03:49 PM
DV57
Mar 2, 2012 06:03 PM
R2D2
Oct 3, 2011 12:50 PM
dgilaon4
Jul 22, 2009 04:33 PM
