P0748 code and occasional odd shift
Old Feb 21, 2019 | 10:10 PM
Ben Matheson's Avatar
Default P0748 code and occasional odd shift
Scanned my system for codes after a few odd shifts 3-4 seemed to hiccup and there was a quick buck. No M S lights or any other indications. Can anyone shed any light on this code?
Old Feb 22, 2019 | 08:24 AM
Lisa Bunch's Avatar
Don't know about the code, but a MAF sensor affects shifting. When mine was bad, it would not shift into 4th unless I hit 50+ mph and let off the gas quickly.
Old Feb 22, 2019 | 08:32 AM
The code is a transmission code as I stated above
Old Feb 22, 2019 | 01:07 PM
Llamasayswhat's Avatar
Is this the first time the code has come up? Any history with the vehicle? It looks like its going to be a likely wiring short, bad TCU, or bad solenoid in the tranny.
Clear the code, see if it returns.
If it does, you're gonna have to spend some time checking connectors and voltages
DTC P0748
Pressure regulator check (S/C to +12V).
Possible causes by suggested order of priority:
^ C193/53 (OLG) shorted to +12V.
^ ECU fault.
C193/53 (OLG) Shorted to +12V.
CHECK THE FOLLOWING:
^ Disconnect EAT C193 before measuring voltage between C193/53 (OLG) and vehicle earth.
ACCEPTABLE RESULTS
^ Between 0.0 V and 4.0 V.
DIAGNOSTIC HINTS
^ If the voltage is above the acceptable range check the harness connected to C193/53 (OLG) for short circuit to +12V.
ECU Fault.
^ Ensure that the check for short to +12V has been carried out.
^ Check transmission ECU by substitution with a known good unit.
POSSIBLE FAULTS
^ Faulty transmission ECU.
Old Feb 22, 2019 | 01:14 PM
DTC P0748
^ ECU fault.
ACCEPTABLE RESULTS
DIAGNOSTIC HINTS
ECU Fault.
POSSIBLE FAULTS
thanks. Yes I plan to start at the wiring connectors. I've cleared the code and will check daily as it didn't throw a warning light.
TestPoint
Jul 11, 2016 09:44 AM
film842
May 2, 2015 10:21 AM
ggushee
Oct 11, 2014 01:27 PM
petstarfish
Jan 5, 2014 02:29 PM
jrm123180
Feb 24, 2012 12:24 PM
