priming oil pump
Old Feb 21, 2019 | 01:39 PM
ejdavis330's Avatar
3rd Gear
Default priming oil pump
Is there any other way to prime the oil pump after it has been installed?
Old Feb 21, 2019 | 03:16 PM
Llamasayswhat's Avatar
It should self-prime within a few moments of running/cranking. If it isnt priming, you may have other issues.
Did you make sure you installed the o-ring on the pickup tube?
Old Feb 21, 2019 | 05:32 PM
Extinct's Avatar
Google priming LS1, there are several methods of priming. Its actually a good bit easier on the Disco, you can screw a fitting in to the oil filter housing with a hose attached and either gravity fill or pressure fill from there.
Old Feb 21, 2019 | 05:33 PM
ejdavis330's Avatar
3rd Gear
yes I did the o-ring
Old Feb 21, 2019 | 05:37 PM
What was the reason for replacing your oil pump? Did you get a new replacement gear set? Used? Did you get a new whole cover assembly?
Old Feb 21, 2019 | 06:33 PM
ejdavis330's Avatar
3rd Gear
There was a leak so I replaced the gasket. When I took the gears out of the pump I noticed the outer one was cracked so I replaced them as well. Replaced the oil pan gasket and new filter as well
Old Feb 21, 2019 | 07:09 PM
Best4x4's Avatar
I’ve packed em with vaseline and never had an issue. You “should” technically be able to coat the oil pump gears in oil, close it all up & upon startup within 10sec have oil pressure.
Old Feb 22, 2019 | 01:22 PM
did you replace the pump with a used pump? The pump and cover wear together and have a very very fine tolerance. Transferring old pumps into old covers always feels like bad juju to me. Did you check the cover carefully? Any scoring or wear? How about the "new" pump?
You still havent answered as to what is actually happening. Are you having a low oil light? Clattering lifters? Did you check oil pressure with a gauge? Flying blind here..
Old Feb 22, 2019 | 02:28 PM
mollusc's Avatar
pull the fuse for the fuel pump. turn the key for 10 seconds or so. reinstall fuse.
308nut
Dec 6, 2012 06:57 PM
curtis d.sr.
Mar 2, 2012 03:16 PM
DeepBlueWater
Sep 25, 2011 06:48 PM
Rover Curious
Aug 20, 2009 01:33 AM
dogs55
Aug 3, 2009 06:31 AM
