P1231 - Fuel pump relay fault Drive cycle A:Signal out of range - below minimum
Old Feb 11, 2025 | 06:14 AM
mcbrl's Avatar
Default P1231 - Fuel pump relay fault Drive cycle A:Signal out of range - below minimum
Hello,
Disco 2 2004 V8 - car runs fine, no problem. Starts on first crank - even after one week being off.
But Nanocom shows me this error. Erased it and it comes back up.
-> P1231 - Fuel pump relay fault Drive cycle A:Signal out of range - below minimum
I would like to sort this out before it gets me stranded.
Any tips on what to check / look for?
Thanks!
Last edited by mcbrl; Feb 11, 2025 at 06:54 AM. Reason: Make the error code more clear
Old Feb 11, 2025 | 11:40 AM
rikkd's Avatar
I'd delete the fault and see if it comes back. Sometimes these cars will throw a code if the voltage is a tad bit too low. It could also be a faulty/finicky relay. You can swap relays around after deleting the codes and see if the code pops up again.
Old Feb 14, 2025 | 03:30 PM
mcbrl's Avatar
Cleared the errors - took it for a ride; the error came back.
I then swapped R1(pump) with R3(headlamp wash), cleared the errors and took it for a ride.
Errors gone! Found the culprit!
Thanks!
Old Feb 14, 2025 | 09:54 PM
rikkd's Avatar
Glad you found and solved the issue!
redrover75
Jul 2, 2023 12:57 PM
frankh
Jan 3, 2017 01:32 PM
NhudeST
Apr 15, 2009 08:48 PM
roverrick
Dec 26, 2007 02:28 PM
CraigR
Jun 28, 2006 02:26 AM
