P1590 and Idle Air Control Valve?
Old Nov 7, 2016 | 11:31 AM
Tony C's Avatar
Question P1590 and Idle Air Control Valve?
My '01 Disco II started 'stumbling' when trying to accelerate, then died altogether. Turns over strong, was running just fine before this occurred. Research and past experience told me 'idle air control valve', but the DTC read P1590. Replaced the idle air valve with a salvage yard unit, still will not start. Cleared the DTC, no change. Before I have it towed to the local LR Dealer, anything else I should try? HELP!!!
Old Nov 7, 2016 | 01:05 PM
d.a.r.y.l's Avatar
It could be the crank position sensor. Befor changing that try starting it with a little gas peddal pressure while it's cranking. If it is the IAC it will start but not idle with help from the gas peddal. JMO D*
simonparrish
Mar 8, 2013 10:06 AM
Suede
Apr 28, 2010 10:07 PM
me3ps
Nov 25, 2009 08:12 PM
discoboy
Feb 7, 2009 04:56 PM
bearcatfans
Dec 18, 2007 09:01 PM
