Panhard bar conversions Q's
Old Sep 11, 2014 | 03:11 PM
vette427sbc's Avatar
Originally Posted by ZGPhoto
D1s had a beautiful rear link setup, no need for a panhard back there.
You just need to match your current setup with the new rod. You can adjust it longer or shorter after installing.
Thats what I cant figure out... The roll center is an imaginary point under the car. Ideally, the panhard bar should intersect this point that is already found by the watts linkage. You would think finding where the roll center on a watts link should be, would be an easy google search but I cannot find anything pertaining to this. Too high or two low changes the roll characteristics of the car. Yes I know its a lifted solid axle truck, but the thing I love about my disco is that it drives significantly nicer than any of my jeeps and I dont want to change that.
Old Sep 11, 2014 | 03:55 PM
ZGPhoto's Avatar
You could always just mount it in and then adjust it afterwards?
Old Sep 11, 2014 | 04:01 PM
According to Murphys law, I will mount it and then need to max out my adjustment leaving me no room to adjust it when I lift it more.
Also, any thoughts on matching the frame brackets front and rear? (ie: both left side)
Old Sep 11, 2014 | 05:01 PM
ZGPhoto's Avatar
I don't have an opinion on it... haa
Old Sep 11, 2014 | 11:37 PM
dusty1's Avatar
I opposed the mounts for more symmetry in weight displacement, you could do the same side.. your arms and shocks are the limitation on the rear, now, anyway.
I just...cut the watts mounts off as close to the root as possible, plate your area on the frame, tweak/grind/cut your frame mount to give desired angle, tack the mounts, use a strap or whatever to center the axle/chassis, measure the rod length (leaving no room for a lengthening adjustment), cut (I used a piece of plumbing pipe for mock up....I forget the id, but it worked with the ends) , ramp it (I use homemade bs ramps at opposing axle tires.....shock-less), make sure you are clear, adjust if needed, cut dom to match mock up, weld, done
about 2 hrs labor
vette427sbc
Dec 25, 2014 01:58 PM
Glasshaus
Dec 24, 2014 07:01 PM
honda50r
Feb 15, 2013 10:47 AM
collector87
May 16, 2012 05:11 PM
2003Disco2
Appearance & Camping Set Ups
Apr 21, 2009 04:54 PM
