Panhard rod question
Old Feb 19, 2014 | 04:03 PM
primussucks's Avatar
Default Panhard rod question
So I bent my panhard rod last time I was out wheeling. I got a replacement 'adjustable' Terrafirma one.
Question is, how do you set it? The adjustment that is. I get that one end screws in and out, but where am i adjusting it to?
Old Feb 19, 2014 | 04:15 PM
dusty1's Avatar
haha. in! I'm looking at the same situation. where to scoot the axle. align shaft or trying to equalize wheels to truck? dunno. Let me know, too.
Old Feb 19, 2014 | 05:08 PM
ralphobell's Avatar
I don't have the answer, but if you call who you purchased it from I'm sure they could tell you. If you purchased from Lucky 8, Rovers North, or Atlantic British they are always helpful with answering these kind of questions.
Old Feb 19, 2014 | 05:36 PM
ZGPhoto's Avatar
2 ways, of course, as usual there's a cheap and easy, and the right way.
1st way, with the truck on flat ground and wheels straight, remove the old one, adjust the new one to length and install.
2nd way(better) Install it the 1st way and bring it to an alignment shop that knows how to work on 4x4s. They should be able to adjust it properly to keep the axle straight.
Old Feb 20, 2014 | 08:11 PM
SuperSport's Avatar
Not sure if this applies to the Rover, but maybe it's a good starting point?
ZGPhoto
Jun 20, 2013 08:31 AM
coors
May 2, 2013 01:22 PM
coors
Jan 30, 2013 02:25 PM
JPSpen
Oct 15, 2012 10:51 AM
moomoo
Jun 16, 2011 08:20 PM
