Parasitic Draw killing battery.
Old Nov 30, 2021 | 03:55 PM
Sandman614's Avatar
Originally Posted by Discorama
I measure that too, ECU & BCU draw that much when ignition is off. When you lock the doors via the remote the current consumption goes down after several minutes, since these units are put into sleep mode. Just tamper the hood switch with a clamp, lock the doors and come back half an hour later. Current draw should be down significantly to several milliamps.
Draw was down to about 200ma after a bit and opening the door shot it up to 1.1a. Even that low still seems too high and a large group 65 agm shouldn't be dead sitting for a week.
Old Nov 30, 2021 | 11:03 PM
Discorama's Avatar
That is definitely too much when you lock it with the remote. I can't remember what I measured exactly, but it was way below 100mA.
Old Dec 1, 2021 | 10:36 AM
Sandman614's Avatar
Figure these videos might help someone with this
Old Dec 3, 2021 | 02:28 PM
cybercop's Avatar
So far just tracked to two low beam bulbs blow, AT THE SAME TIME. replaced and now everything is normal. WEIRD!!!!
Old Dec 4, 2021 | 10:32 AM
Xanthro's Avatar
Check the wiring you may have a short.
Anthony Rowlett
Oct 7, 2019 06:55 PM
rlrigsby
Apr 2, 2012 03:15 PM
Savannah Buzz
Jan 13, 2012 03:37 PM
SUMOSINO
Jul 20, 2009 09:10 AM
wizardmagu
Nov 11, 2008 11:05 PM
