Part number or source
Old Oct 1, 2013 | 02:05 AM
Phatrowles's Avatar
Default Part number or source
I was cleaning out my PCV system tonight and cracked a small plastic fitting that connects the passenger side PCV hose to the throttle body. It was black plastic, threaded on one side and had a hose fitting on the other side. Does anyone have a source where I can find this part, a part number or a name of this part?
It connects to this hose: Hose - Valve Cover To Plenum (From Xa) (Genuine Part # ERR7411) - Land Rover radiator hoses from Atlantic British
Old Oct 1, 2013 | 07:49 AM
The Microcat (parts index and exploded diagrams) is on line at lrparts.ru. You have to select the English option. But plastic barb fittings are pretty common, you may be able to go generic.
Old Oct 1, 2013 | 08:39 AM
ZGPhoto's Avatar
Unfortunately MC isn't of MUCH help here, as it shows the hose on the valve cover side.
Can you post a photo of the connection you're referring to?
Old Oct 1, 2013 | 08:40 AM
ZGPhoto's Avatar
The hose you're referring to is #11 in the photo by the way.
Old Oct 1, 2013 | 09:50 AM
acamato's Avatar
part no: ERR6880
Intake Manifold Fitting PCV Hose To Valve Cover (Genuine Part # ERR6880) - Land Rover miscellaneous from Atlantic British
get a brass 1/4" NPT x 3/8" adapter. (I got mine at Lowes) Use a clamp to ensure the hose gets a good seal.
https://landroverforums.com/forum/di...fy-part-61482/
Old Oct 1, 2013 | 10:39 AM
Phatrowles's Avatar
This is a picture of it. It is the black plastic connector between the plenum and the top hose (#11). I really appreciate all the assistance!
Old Oct 1, 2013 | 10:45 AM
ZGPhoto's Avatar
^Then acamato has your info, cheers!
Old Oct 1, 2013 | 06:48 PM
Phatrowles's Avatar
You guys are awesome! I will do that tonight. Thanks a ton.
DonRW2007
Jan 6, 2014 09:19 AM
grandkodiak
Mar 14, 2013 05:15 PM
Disco2Guy
Oct 12, 2008 11:49 PM
pilsner
Aug 27, 2008 08:11 PM
Raider TD5
Defender
Aug 9, 2008 05:43 AM
