Parts for adding jump seats
Old May 30, 2018 | 06:13 AM
Fastercat's Avatar
Default Parts for adding jump seats
I’m wanting to add the rear jump seats to my truck and have found a couple guys who are are parting out the 7 seaters. Can anyone tell me what all parts I need to convert mine?
i just want to make sure I get everything I need as there both 4 hours away.
Old May 30, 2018 | 06:28 AM
shanechevelle's Avatar
Allot
Brackets, side panels, headrests...
There's mounts that have to be welded into the floor, holes to be drilled and threaded.
I believe there's a difference in suspension and you'll need the rear step that's under the bumper.
It's a mess.
I part out 7 seaters and usually sell just the seats for 2-300. If it were easy I'd have extra seats in mine.
Old May 30, 2018 | 06:52 AM
mollusc's Avatar
Suspension is the same, but you also need seatbelts as well as what was mentioned above. The jump seats are also monstrously uncomfortable.
Old May 30, 2018 | 06:55 AM
zuke's Avatar
And even the ones with seats installed at the factory rattle. First thing I do is take them out. I have quite a collection. I was overjoyed to find an SE with the toolboxes instead.
Old May 30, 2018 | 06:57 AM
JUKE179r's Avatar
You’ll need the rear door inside panel handle since it is actually bolted to the door and not just to the inside panel.
Old May 30, 2018 | 08:12 AM
Fastercat's Avatar
Ok thanks guys, I’ll probably only install 1 seat on the passenger side. I have 3 kids who elbow and fight each other if it’s a long ride. It would help my sanity if I could separate them a bit. 2 are still in boosters so space is premium.
Old May 30, 2018 | 09:11 AM
OverRover's Avatar
I bet these would work great, and you can save yourself some time and money.
Old May 30, 2018 | 09:19 AM
abran's Avatar
No welding needed, all holes are there. I have installed them and just bolted up. One guy I sold a set to told me he had to tap the holes, but I think he was just removing the paint.
Make sure you get the floor brackets. If only installing one side do the passenger side. The driver side has the extra bracket to clear the AC system, this way you can keep your storage cubby on the driver side. Besides the seat belts you need the upper ivory panels the seat belts thread through. There is also a small bracket that bolts to the floor that holds the seatbelt behind the lower cargo panel.
Old May 30, 2018 | 09:33 AM
What holes. My and every rover that had the tool boxes didnt have the holes for seats. Been down this road countless times with people...
The seats have to latch into the floor.
If you add this seat, and you get rear ended, the passenger in that seat may die...and it may come back on you because you modified something that shouldn't have been. Same reasons why car seats have expiration dates.
Dave03S's Avatar
Aren't there some concerns with insurance not covering a modified vehicle? If you make one mistake and one of your kids suffers I believe you are on the hook.
