Pass side window
the clicking sound is more than likely the gears on the motor have went past the regulator gear, due to the plastic rollers wearing out. normally a regulator is needed, although people have replaced the rollers.
Discovery II Power Windows Rollers V5 (ZQNHTF3LW) by Georges_Payne
kelren31 (07-27-2015)
It may be either as Joemamma1954 states or the center pivot of the semi circular gear worn out or the actual semi circular gear has stripped. Whatever, it's going to take either a new regulator and/or motor or a repair. Aftermarket motorised regulators are very cheap to buy, circa $20 on Ebay plus the motor if it's that which is often unlikely.
I assume 'pass side' you mean RHS on a LHD truck.
kelren31 (08-02-2015)
kirk4
06-26-2008 11:54 AM
mikemeyer0
01-10-2006 01:30 AM
