Passenger Door Lock Not Working
Old Dec 5, 2012 | 08:26 PM
Bkreutz's Avatar
Originally Posted by Disco Alan
jhill, your link with pictures should really help! Thank you very much.
Does anyone happen to know if this is the right part?
Land Rover Discovery II Actuator, Right Front Door (Genuine Part # FQJ102900) | Land Rover Electrical Parts
It's $20.00 cheaper at this dealer (I've used them a number of times, not sure how they beat everyones prices as often as they do, but it pays to shop around) Actuator
Old Dec 10, 2012 | 01:46 PM
Disco Alan's Avatar
Thanks to jhill's link with pictures I was able to tackle the lock actuator in just under 2 hours. However, I brilliantly dropped the 13mm hex bolt that holds the window frame into the door pocket. As far as I can tell there is no access to this closed space. I don't mind leaving it in there. Is this something I can get from a hardware store? If so does anyone have the spec for it? Thank you.
Old Sep 11, 2019 | 02:00 PM
JoseLopezthe2's Avatar
Default Still no luck
I have a similar issue where the passenger door is not responding to the central locking unit or the key fob. And it’s locked shut, how would I get it open now to fix the door.
Originally Posted by jhill15
Testing the electrical plug that goes into the latch is a good idea however at that point you have taken half of your door apart you may as well finish the job. The door latch aka door acuator is not unlocking or locking because it is bad. The electrical signal is sent to it, it just doesn't work or actuate. Bad door latch that needs replaced.
EastCoastWarrior
May 9, 2011 08:54 PM
gavone1976
Mar 10, 2011 01:08 PM
seamuspg
Sep 18, 2009 05:59 PM
ITMagician
Feb 1, 2008 09:18 AM
