Passenger exhaust manifold 2003
Old Oct 20, 2017 | 12:22 PM
PosterNutbag's Avatar
Default Passenger exhaust manifold 2003
I’m trying to track down an exhaust leak and the first thing I tried was looking at the connection between the headers and the y pipe. Drivers side is locked in with three nuts. However when I went and looked at the passenger side from underneath I saw two bolt heads directed up and the third hole looks like it has a stud coming through the bottom but there’s not enough sticking out to thread a nut. On the top side, the two bolts stick right out the top with no nuts and the short stud from the third hole looks like it goes right into the meat of the exhaust header. Is this right? Seems to me like there’s a lot missing here, maybe that short stud should be sticking out more so I can nut it, and those two bolts should have nuts on the top side.
Also, the previous owner left out 1 of 8 bolts mounting each manifold to the cylinder heads. Odd. I even got 2 bolts to slip in there but the holes aren’t lined up, guess that’s why he left them out.
Old Oct 21, 2017 | 11:01 AM
LR03NJ's Avatar
Maybe the stud was inserted incorrectly. One tread is longer than the other. If you think you have an exhaust leak, just tighten it or get a complete gasket with stud kit. These trucks get all kinds of leak including the exhaust parts. If you cant align the bolt to the manifold, just loosen them and with a help of a jack, jack up the exhaust pipe or a part of the cats slowly to align the bolt.
Old Oct 21, 2017 | 02:24 PM
number9's Avatar
Supposed to be 3 studs in the exhaust manifold and y-pipe held with 3 nuts per side. Short stud likely broken and other studs had been replaced by the bolts. You can purchase replacement stud/nut sets and gaskets.
cjaclwill
Feb 6, 2013 04:38 PM
twaszak
Jul 15, 2012 07:21 PM
raid13
May 13, 2007 10:22 AM
portman
Jan 3, 2006 05:26 AM
beavis4g63t
Jul 12, 2005 05:27 PM
