Passenger Side Footwell Water
Old Feb 6, 2023 | 04:18 PM
mackendw's Avatar
If I had been clearly thinking, I would have run the air conditioner again BEFORE I had fixed the drainage lines after I had dried the floor mats out and seen if the water
was coming in from ONLY these lines backing up. but alas....
I'll watch these 2 other sources as being culprits if water re-occurs.
thx.
Old Feb 6, 2023 | 04:28 PM
Harvlr's Avatar
As XRAD said, mine had water pouring into the fresh air intake (for the HVAC blower). I made a plastic baffle above the intake to direct the water away. (Sorry, I neglected to take photos). This was the reason my D2 was dirt cheap, as the water had gotten into the ECU and caused the engine to not run.
Old Feb 6, 2023 | 04:39 PM
mackendw's Avatar
you mean the 1 1/4" 4 ft long section under the hood that has the foam embedded inside it? you built a piece of plastic to direct water coming in via the hood and send it down below the engine and out I'm assuming.
Old Feb 6, 2023 | 05:21 PM
Harvlr's Avatar
No, the actual air inlet box for the blower
Old Feb 6, 2023 | 05:36 PM
mackendw's Avatar
oh.... pic of where it is would help then.
Old Feb 6, 2023 | 09:24 PM
coors's Avatar
Originally Posted by redrover75
Check the top, outside corner, by the windshield. That corner sometimes comes unsealed, if you cover that corner with silicon, it may clear it up.
This There was a TSB issued many moons ago by LR.
If and when your sunroofs leak there will be signs of water intrusion near the upper A pillar headliner area.
JEFIII
Feb 5, 2023 08:31 AM
dammad
Jun 25, 2009 01:08 AM
Aj6543
Jun 1, 2009 11:50 AM
Bob2003Discovery
Oct 5, 2008 10:49 PM
rjaime6
Jul 12, 2008 10:53 PM
