Passenger window won't go down
Old Aug 6, 2013 | 10:07 AM
jamieb's Avatar
Default Passenger window won't go down
Hi, front passenger window will only come down about 1/4 inch on the back side. I took off the door panel and see the glass sits in a rail. There is an arm on the right side that has a plastic sleeve that has split in two parts. The sleeve goes around the part of the arm seated in the rail. I manually tried to get the glass to go up and down with my hands as my wife pressed the switch up and down. No luck. Also, in the upmost position there is little visibility and barely any access to touch parts. Even with the glass trim removed, no luck.
Any tips or ideas short of a glass shop? Any ideas the cost to repair something like this?
Thanks!
2002 Land Rover Discovery II
Old Aug 6, 2013 | 10:13 AM
ZGPhoto's Avatar
You need a window regulator. We have them for $69.00 and the installation takes roughly 30-45 minutes if you've never done one before. Here's the link to the part: REGULATOR RH FRT WINDOW '95 RANGE ROVER CLASSIC, DISCOVERY I, DISCOVERY II, PLH542, LR006373 - Rovers North - Classic Land Rover Parts
And here's the link to the detailed install instructions: https://landroverforums.com/forum/di...-repair-34345/
Old Aug 6, 2013 | 10:17 AM
jamieb's Avatar
Thanks! I will look over these links.
Xrover
Dec 14, 2012 06:25 PM
southfloridadiscoII
Oct 21, 2012 06:33 PM
Nessa767
Apr 7, 2012 09:19 AM
Newfoundlandrover
Oct 2, 2011 06:51 PM
jw928
Feb 6, 2010 06:51 PM
