PCV mod... maintenance required?
Old Oct 16, 2021 | 02:53 PM
Brandon318's Avatar
Default PCV mod... maintenance required?
Some of us have been running this mod for a ton of miles by now, and I'm wondering if any maintenance should be done on the valve? Remove and inspect? Clean?
Old Oct 16, 2021 | 03:57 PM
Xanthro's Avatar
They are so inexpensive, just change it out if worried, though it's new placement makes it less likely to foul.
Old Oct 16, 2021 | 07:07 PM
Discorama's Avatar
My PCV valve got dirty inside after 28k Miles. I cleaned it with carb spray. Make sure it rattles, opens with slight pressure (mouth) from one side and blocks from the other side. It is a 5 minute maintenance item.
Old Oct 18, 2021 | 07:50 AM
jastutte's Avatar
i spray mine out with carb cleaner every oil change.
something to do while all the oil drains.
Old Oct 18, 2021 | 12:27 PM
uhoh_elmo's Avatar
Has anyone ever used a catch can with the PCV mod? I wonder if that would make that much of a difference on fouling.
andino
May 18, 2021 12:27 PM
vanbadri
Apr 18, 2019 11:33 AM
Oasisplayer311
Jul 15, 2016 10:12 AM
MC04DII
Nov 21, 2012 05:50 AM
