Pcv mod question
Old 06-17-2023, 06:41 PM
Rrr_bhb's Avatar
Default Pcv mod question
Hi all,
I was going to do the PCV mod on my 2004 disco2 and i dont see the plastic baffle on the oil seperator end. All there is, is a metal tube. See pic.
Do I remove this from the valve cover? Any ideas on how to easily remove it?
thanks in advance!
Old 06-17-2023, 07:29 PM
Rrr_bhb's Avatar
Ok. So I do need to remove this tube. Is it a pull off or screw off? Any tips please!!!
Old 06-17-2023, 07:37 PM
Extinct's Avatar
Received 1,431 Likes on 1,019 Posts
Grab the end with a pair of pliers and twist till the tube comes out. Once it is out, cut the end with the disc off of it with a tubing cutter. Then drill the plastic baffle out and just tap the tube back in the valve cover
Best4x4 (06-18-2023)
Old 06-17-2023, 08:06 PM
Rrr_bhb's Avatar
Thanks. So it’s not a screw on, but just tapped in place? Im soaking it with penetrating oil. Hopefully it comes out!
Old 06-17-2023, 09:55 PM
Discorama's Avatar
It's just pressed in, but it came lose very easily on mine. Put a short piece of rubber hose over the tube (to prevent scratches) and try to wiggle it with a vice grip.
The following 2 users liked this post by Discorama:
Best4x4 (06-18-2023), V50-M66 (06-18-2023)
Old 06-18-2023, 09:26 AM
mln01's Avatar
Originally Posted by Discorama
... try to wiggle it with a vice grip.
The term is actually Vise Grip, not vice grip. Vice grips would be something else entirely ...
This from a proud Nebraskan, where Vise Grips were invented (Petersen Manufacturing, DeWitt, NE).
Richard Gallant (06-18-2023)
Old 06-18-2023, 01:37 PM
Discorama's Avatar
Sorry, for that. English is my third language.
Old 06-19-2023, 05:41 AM
Xanthro's Avatar
Originally Posted by Rrr_bhb
Hi all,
thanks in advance!
The easiest way to pull the PVC tube out is with Hose Pliers. These have a little round open tip at the end to grab hoses. It will grab the PVC tube and easily pull it out.
Harbor Freight sells a set for cheap.
I have SAI, so it's crowded around that area in the engine, and I struggled to pull it out with various regular pliers. Hose pliers took seconds.
Old 06-19-2023, 12:46 PM
Rrr_bhb's Avatar
Thank you all for the suggestions. I soaked it it penetrating oil for a day, then got a vise grip from Harbor freight and it took me a few seconds to wiggle and pull it out. I cant’t believe its just held in place by tapping, but oh well.
I was able to push out the plstic baffle and enlarge the hole with a drill. Managed to get some minor scuffs in the process but looks like the hose went back on it nicely and the truck feels a tad bit smoother and less noisy. Thank you all again!
V50-M66 (06-19-2023)
Old 06-20-2023, 06:13 PM
Frank4's Avatar
This one is new to me. What’s the advantage of pulling that out and what do you do with the hose that connects to it?
thanks.
Roont (08-14-2023)
Quick Reply: Pcv mod question
