Penetrating oils! Get-cha penetrating oils here!
Old Mar 26, 2018 | 06:54 AM
OverRover's Avatar
Originally Posted by JUKE179r
Thanks for the video Alex!
Here is an old military maintainer trick that I use... heat up real stubborn rusted hardware with a propane torch then dab it with a stick of wax. The wax gets deep into the threads for easy removal.
I learned the wax trick from my Father what feels like a 100 years ago now.
Capillary action is a good thing, and it's almost scary how well/fast it works.
Old Mar 26, 2018 | 07:50 AM
Alex_M's Avatar
It's a great trick as a last resort, but heating up a bolt destroys the heat treat. If you do that you always want to replace the hardware. Probably should anyway if it was rusted, but alas.
Old Apr 7, 2018 | 12:23 PM
Alex_M's Avatar
Second set of tests is out, now including the famed Kroil! Looks like I'll be sticking with ATF/Seafoam for now.
Old Apr 7, 2018 | 12:58 PM
Sixpack577's Avatar
I've used Kroil for many years.
When nothing gets a rusted bolt out, Kroil always does.
Old Apr 7, 2018 | 01:12 PM
CollieRover's Avatar
https://youtu.be/YeTNXbDbHcM
i just got some wd40 penetrating rust dissolving formula, but I have some atf and seafoam hanging around. I’ll use the wd40 on drivers side of the exhaust manifold, and atf seafoam on the passenger side.
Old Apr 7, 2018 | 01:13 PM
Friday Night Disco's Avatar
WD-40 will continue to be my choice, thanks for posting the video
jameswarwick
Defender
Jan 21, 2009 10:14 AM
unstable
May 12, 2008 07:08 AM
okdiscoguy
Aug 3, 2007 06:16 PM
johnnybob06
May 14, 2007 11:31 AM
