Performance Chip?
Old Feb 1, 2009 | 05:12 PM
Disco2Guy's Avatar
Default RE: Performance Chip?
Try increasing the tire pressure by a few pounds and keep accelerations under 2k while in town.
Old Feb 2, 2009 | 08:15 AM
daniep's Avatar
I get about 13 mpg butI guess thats what everyone gets. Thanks
Old Feb 2, 2009 | 10:22 AM
unimoged's Avatar
DO NOT buy or USE THIS PIECE OF !@#$ potentiometer. It will set code code DTC P0113 (Intake air temp voltage too high).
Basically, this is a variable resistor that attachs to the IAT sensor harness, allowing the voltageto be returned high to ECU making the ECU think that it is freezing cold weather and therefore richening your mixture.
But the ECU after multiple cycles will compare IAT to ECT voltage (engine coolant temperature) and it will set a fault code if the variance is higher than mapped.
Quinn519
May 6, 2014 06:35 AM
Lil Bear
Dec 19, 2012 09:18 AM
calebbo
Feb 23, 2011 08:30 PM
pizzaboy
Jan 20, 2011 12:12 PM
fri3daz3
Oct 21, 2008 04:35 PM
