Perplexed with leaky anti freeze?
Old Apr 7, 2017 | 10:04 PM
brooksa's Avatar
Default Perplexed with leaky anti freeze?
Here is something for everybody to chew on,
I am leaking green anti freeze, ok they all leak at some point, however I am not using green anti freeze?
Old Apr 7, 2017 | 10:15 PM
KingKoopa's Avatar
burn it. BURN IT WITH FIRE!!
that sounds like some land rover HIV, if that **** spreads there will be an epidemic!
Old Apr 7, 2017 | 10:27 PM
brooksa's Avatar
I mean no freaking joke! I had to go back and look 2 or 3 times and yep still green!
Old Apr 8, 2017 | 12:13 AM
Dave03S's Avatar
You should be using green anti freeze. You've pissed off the Rover Gods.
Old Apr 8, 2017 | 12:41 PM
OverRover's Avatar
I'll bet you a $1 at some point someone added a few bottles of "Mechanic in a Can" that was green to "fix" a head gasket/radiator leak. Well that never works! I've seen this happen on a GMC truck.
Just start fresh, flush this pig and use some proper coolant.
And just for giggles, where do you see the leak?
Old Apr 9, 2017 | 09:01 AM
LR03NJ's Avatar
How green? Pentosin is green, power steering fluid but it drips very dark green in color. Or, you must be using yellow coolant and mixed with blue coolant or windhield wash. Drain and replace just to be sure its not contaminated.
Gerry
turf63
Jul 8, 2010 07:42 PM
ggushee
Nov 21, 2007 03:47 PM
Discochick
Jul 4, 2007 05:15 PM
ggushee
Jun 17, 2007 10:47 AM
37chambers
Aug 22, 2005 10:40 PM
