Pics: What is this part called?
on
No, in the future, you might want to find out what a part is so you won't damage something.
The idle control unit will not cause a 441, which is an incorrect purge flow fault for the evap system or the 1590 which is because your 3 Amigos are on.
Do you know how to clean your throttle body and the idle control unit? If so I would do that and see if you can save having to replace it.
Thanks
Robert
Before I tore my engine apart, my IAC was making all kinds of terrible noise. I took it off, and cleaned it with carb cleaner. I made sure the little straw pointed on the inside and kept spraying until the cleaner ran clear. Fixed the problem too, now it's quiet as could be.
on
Cleaning it, along with the t/body, will make for a smoother idle and a more responsive exceleration.
