Pics: What is this part called?
Old Jun 9, 2009 | 02:50 PM
aublec22's Avatar
Default Pics: What is this part called?
Can any one tell me what this part is?
It has been clicking during idle i thought it was the purge flow valve but i just can't be sure
Old Jun 9, 2009 | 03:06 PM
jycsalas's Avatar
idle air control valve
File Type: pdf
Old Jun 9, 2009 | 03:11 PM
aublec22's Avatar
sweet thanks... could this malfunctioning cause the fault codes of p1590 or p0441?
Old Jun 9, 2009 | 04:31 PM
No, in the future, you might want to find out what a part is so you won't damage something.
The idle control unit will not cause a 441, which is an incorrect purge flow fault for the evap system or the 1590 which is because your 3 Amigos are on.
Do you know how to clean your throttle body and the idle control unit? If so I would do that and see if you can save having to replace it.
Old Jun 9, 2009 | 10:16 PM
Night Train's Avatar
Mike I have a handle on cleaning the throttle body but, how do you clean the Idle control unit? and - is it required? like whenever you clean the T.B.
Thanks
Robert
Old Jun 10, 2009 | 06:15 AM
tornado_735's Avatar
Thanks
Robert
Before I tore my engine apart, my IAC was making all kinds of terrible noise. I took it off, and cleaned it with carb cleaner. I made sure the little straw pointed on the inside and kept spraying until the cleaner ran clear. Fixed the problem too, now it's quiet as could be.
Old Jun 10, 2009 | 08:21 AM
Jawbox's Avatar
What kind of noise does a dirty IAC make? I'm hunting down a loud squeal.
Old Jun 10, 2009 | 08:31 AM
Thanks
Robert
Is it required, maybe not, especially if a driver is not to mechanical and doesn't pay any attention to how his truck runs.
Cleaning it, along with the t/body, will make for a smoother idle and a more responsive exceleration.
Old Jun 10, 2009 | 12:07 PM
aublec22's Avatar
Thank you i did just replace the throttle body b/c is was leaking coolant. Should I still clean the iac? And I have been looking for a purge flow valve all over. I have one a on back order at atlantic british and have for like 6 weeks!! Any suggestions on where else I might find one?
Old Jun 10, 2009 | 06:27 PM
Mine sounded was buzzing, and humming, and sounded like a fan motor that was running dry.
thehun
Mar 7, 2013 01:35 AM
Bundu
Apr 8, 2011 01:06 PM
Bundu
Apr 4, 2011 08:30 PM
agarabaghi
Mar 23, 2011 11:04 AM
sk_adams
Mar 20, 2010 06:07 PM
