pinging/detonating
Old Jun 22, 2012 | 07:27 PM
eagleton's Avatar
4th Gear
Default pinging/detonating
hi all,
i am after some help on a issue with my disco II ( 99mod)
since overheating i have the following symptoms:
-pinging/detonating under load..idles perfect, drives perfect under at low throttle.
- a smell of coolent. however can not spot any excess around the engine bay!
- heads are leaking a little, but always have.
- the o2 sesnor is covered in oil!! dont know if this is cousing it?
- there is a delayed start now by a 1 second from b4
so basically i am asking if this sounds like a internal water leak/head gasket or do you guys think other?
jason
Old Jun 22, 2012 | 08:29 PM
How much coolant do you add and how often?
Old Jun 23, 2012 | 04:44 AM
eagleton's Avatar
4th Gear
thanks for your reply mate,
yes it is using coolent...apx 250ml per 50k i reckon
i have been using hi octane fuel for the last 50k's and it seems to have eliminated the prob?
a note also:
this pinging/detonating does not happen when the car is cold!
jason
Old Jun 23, 2012 | 06:01 AM
tee51397's Avatar
I'd start with a compression check.
Also could be a crank sensor which would also explain delayed start.
Old Jun 23, 2012 | 07:24 AM
Better yet, do a compression test, since you are loosing coolant. My money is on a head gasket. How mechanical are you?
Old Jun 23, 2012 | 10:41 AM
a note also:
jason
So you are using almost half a qt of coolant every 30 miles or so, that's cause for concern.
These trucks require high octane fuel all the time.
Time for new head gaskets.
Old Jun 23, 2012 | 09:42 PM
eagleton's Avatar
4th Gear
thanks for the feedback.
compression test sound like a good idea, will get one done.
will get gaskets done also
i didn't mention that this problem only occurs when car has warmed up 15min or so! " no detonating when cold"
temp sensor
jason
Old Jun 23, 2012 | 09:46 PM
Temp sensor has nothing to do with it, it is either coolant in the cylinders or bad knock sensor(s).
Old Jun 24, 2012 | 04:38 AM
eagleton's Avatar
4th Gear
ok thnx spike.
see how we go!
jason
DiscoHelp
Oct 3, 2011 06:18 PM
sarahgibbons5
Aug 19, 2009 02:16 AM
ljdiscovery
Jan 12, 2009 04:05 PM
mackshawnd
Apr 24, 2007 01:58 PM
teamyonex
Nov 2, 2005 01:08 PM
