Planning a 120k service
Its also a great time to replace the crankshaft seal on the front cover, oil pickup O-ring. Oil filter sump O-ring. All those are reasonably priced at the dealer. There is also an aditional O-ring inside the oil filter sump. If you have any questions I did this job last week. All it pretty straight forward.
Ok before I place the order this is what I go from Atlantic British ... I do plan on adding a oil pressure gauge and accurate temp gauge soon, just not now.
Timing Chain Kit For Land Rovers And Range Rovers | Engine Parts
Land Rover Water Pump (Same Fit As Genuine Part # STC4378): Water Pump Fits Most Land Rover Vehicle Models
Oil Pump Gear Kit W/Gaskets - Land Rover kits from Atlantic British
Thermostat Discovery II (Genuine Part # PEM100990) - Land Rover cooling/heating from Atlantic British
